HP Print and Scan Doctor
  • Support Home
  • Products
    • Printer Support
    • Computer Support
    • Poly Collaboration Devices
    • All
  • Software and Drivers
  • Diagnostics
    • Printer Diagonostic Tools
    • Computer Diagnostic Tools
    • Windows 10 Support
    • Print and Scan Doctor
  • Contact Us
  • Business Support
    • Create a new case
    • Find an existing case
    • Manage contracts and warranties
    • Register an account
    • MyHPSupport Help
    • Security Bulletins
    • Login Required
  • My HP Account
    • Support Dashboard
    • HP Account benefits
    • Service Appointment
HP Print and Scan Doctor for Windows
Fix printing and scanning problems with HP Print and Scan Doctor, a free tool for Windows.
Download Print and Scan Doctor
Having printer issues with Mac? Download HP Smart and run Diagnose & Fix. Learn more here
  • How to Use
  • Fix Printing Problems
  • Fix Scanning Problems
  • How to Use
    • Windows: Download HP Print and Scan Doctor.
    • Mac: Use Diagnose & Fix through HP Smart. Learn more here
  1. Run HPPSdr.exe from the download location on your computer.
  2. Once HP Print and Scan Doctor is open, click Start, and then choose your printer.
    • If your printer is not listed, turn it on and click Retry.
    • If there is a connection problem, follow the instructions in the tool.
  3. Depending on the problem, click either Fix Printing or Fix Scanning.
  4. Test results are displayed with icons
A checkmark means your printer passed.
A wrench means a problem was found and fixed.
An exclamation mark means a test failed and was skipped.
An X means the printer has a problem. Follow the instructions to fix it.
  1. HP Print and Scan Doctor shortcut is installed on your desktop
Read frequently asked questions on using HP Print and Scan Doctor.
If the tool cannot find your printer, read the following lists of troubleshooting tips to connect your printer.
For detailed information on how to connect your printer or if you get an error message when trying to connect, go to the HP Support page, type your printer model, and then search for the document on installing your printer for a USB, wired (Ethernet), or wireless connection or for the error message that displays. Click here
Try these recommendations and procedures to troubleshoot and avoid wireless connectivity issues.
  • Restart the printer and the computer: Restarting the computer and the printer can clear error conditions.
  • Confirm the printer connection and network name: On the printer, make sure the blue light next to the Wireless icon is on and steady. Open the Wireless network menu to make sure the printer is connected to the same network as your computer.
  • Move the printer and router closer together: Move the printer and the computer closer to your wireless router, to within 6 ft (1.8 m). Wireless signals are weaker at greater distances between the printer and the router.
  • Manually connect the printer to the network: Many HP printers have a Wireless Setup Wizard on the printer control panel network or wireless settings menus. Follow the on-screen instructions to connect the printer to the network.
  • Restart the router: If you are experiencing a slow or intermittent wireless connection, restart your router. Consult your router manufacturer, Internet service provider, or network administrator for instructions on how to restart the router.
  • Check the router band setting: Many routers operate in both 2.4 GHz and 5.0 GHz frequency bands, but not all HP printers support both bands. Make sure the 2.4 GHz router band is turned on and broadcasting. If the router broadcasts separate network names (SSIDs) for each band, connect the printer to the 2.4 GHz band SSID.
  • Check your firewall software: Your firewall software might prevent the printer from accessing the computer. Accept or allow any firewall messages that display during the printer software download and installation. You can also configure the software to allow HP downloads and installations.
  • Check for obstructions between the printer and the router: Remove any metal objects between the printer, the computer, and the access point (router). Objects such as refrigerators or metal bookcases can interfere with wireless signals.
  • Check for other devices that emit radio and wireless signals: Move any devices that emit radio signals, such as microwaves and cordless telephones, farther away from the printer.
  • Set the IP address on the printer: Your printer can bypass automatic IP address assignment by DHCP and use any valid IP address you choose. Use the control panel menu to type an IP address that is valid for use on your local area network.
Try these tips and procedures to troubleshoot and avoid wired network connectivity issues.
  • Confirm the network connection: Confirm that your printer is connected to the wired network by checking the cable and the lights on the printer’s Ethernet port. The green link light should be steady, and the orange activity light should blink when the cable is connected.
  • Check the cable: Examine the Ethernet cable attached to the rear of the printer to make sure that it is not a phone cable (Ethernet cables and phone cables look similar but are different sizes).
1. Ethernet Cable
2. Phone Cable
  • Reconnect the cable: Disconnect, and then reconnect the Ethernet cable to the rear of the printer, and then plug the cable into another valid port on the router.
  • Use a different cable: Connect a different Ethernet cable.
Try these tips and procedures to help troubleshoot and avoid USB connectivity issues.
  • Restart the printer and the computer: Restarting the computer and the printer can clear possible error conditions.
  • Reconnect the cable: Disconnect and reconnect the USB cable from the printer and the computer.
  • Connect to a different USB port: Connect the cable to a different USB port on the computer.
  • Disconnect from a USB hub or docking station: If you are using a USB hub or docking station, try connecting the cable directly to the computer.
  • Try a different USB cable: Use a different USB cable. HP supports USB cables less than 3 m (9 ft 10 in) in length.
  • Disconnect other USB devices: If you have several USB-connected devices, such as another printer, the computer might not have sufficient power supplied to the USB ports to detect all of them. Disconnect any other USB devices that are not in use.
HP Print and Scan Doctor is not available for Mac. However, select one of the following links to resolve common printing, connection, or scanning issues.
  • Printer offline issue: If you see an offline message as the status for the printer or a Printer not responding message when attempting to print, go to Printer is Offline (Mac).
  • Print quality issues: If the quality of a printed document or photo is not as expected, go to HP Support , type your printer model number, and then search for print quality to find the Fixing Poor Print Quality document for steps to resolve the issue.
  • Scan connection issues: Go to
  • Scan quality issues: If the computer file or printout has vertical lines, incorrect colors, color bands, or poor resolution after scanning, go to Improving Scan Quality.
HP Print and Scan Doctor detected missing printer software or problems that might be resolved by installing the latest software. If you continue experiencing problems after installing the software, use the previous steps in this document to troubleshoot additional problems.
Is your printer currently offline?
Does your printer display a status of offline or printer offline and the printer does not print?
Yes No
Your software is downloading...
You are currently downloading a version of HP Print & Scan Doctor designed to resolve printer offline conditions.
You will be directed to a set of detailed steps...
If your download does not start, click here
Hp logo
Select registration option
Personal accounts
  • Save your personal devices and preferences
  • Easy access to support resources
Business/IT accounts
  • Managing contracts and warranties for your business
  • Submitting and managing support cases
Privacy Policy © Copyright 2020 HP Development Company, L.P.
Country/Region: Flag
Select your country/region and language
Americas
  • América Central
  • Argentina
  • Bolivia
  • Brasil
  • Canada
  • Canada - Français
  • Caribbean
  • Chile
  • Colombia
  • Ecuador
  • México
  • Paraguay
  • Perú
  • Puerto Rico
  • United States
  • Uruguay
  • Venezuela
Europe, Middle East, Africa
  • Africa
  • Afrique
  • Беларусь
  • België
  • Belgique
  • Bulgaria
  • Česká republika
  • Croatia
  • Danmark
  • Deutschland
  • Estonia
  • España
  • France
  • Ελλάδα
  • Ireland
  • ישראל
  • Italia
  • Казахстан
  • Latvia
  • Lithuania
  • Magyarország
  • Middle East
  • العربية
  • Nederland
  • Norge
  • Österreich
  • Polska
  • Portugal
  • Romania
  • Россия
  • Schweiz
  • Suisse
  • Serbia
  • Slovakia
  • Slovenia
  • South Africa
  • Suomi
  • Sverige
  • Türkiye
  • United Kingdom
  • Украина
  • Bosna i Hercegovina
Asia Pacific and Oceania
  • Australia
  • 中国
  • 香港特別行政區
  • Hong Kong SAR
  • Indonesia
  • India
  • 日本
  • 한국
  • Malaysia
  • New Zealand
  • Philippines
  • Singapore
  • 台灣地區
  • Thailand
  • ไทย
  • Vietnam
Americas
  • América Central
  • Argentina
  • Bolivia
  • Brasil
  • Canada
  • Canada - Français
  • Caribbean
  • Chile
  • Colombia
  • Ecuador
  • México
  • Paraguay
  • Perú
  • Puerto Rico
  • United States
  • Uruguay
  • Venezuela
  • Africa
  • Afrique
  • Беларусь
  • België
  • Belgique
  • Bulgaria
  • Česká republika
  • Croatia
  • Danmark
  • Deutschland
  • Estonia
  • España
  • France
  • Ελλάδα
  • Ireland
  • ישראל
  • Italia
  • Казахстан
  • Latvia
  • Lithuania
  • Magyarország
  • Middle East
  • العربية
  • Nederland
  • Norge
  • Österreich
  • Polska
  • Portugal
  • Romania
  • Россия
  • Schweiz
  • Suisse
  • Serbia
  • Slovakia
  • Slovenia
  • South Africa
  • Suomi
  • Sverige
  • Türkiye
  • United Kingdom
  • Украина
  • Australia
  • 中国
  • 香港特別行政區
  • Hong Kong SAR
  • Indonesia
  • India
  • 日本
  • 한국
  • Malaysia
  • New Zealand
  • Philippines
  • Singapore
  • 台灣地區
  • Thailand
  • ไทย
  • Vietnam
